Hi guys, got some issues with MPG and bad running at the moment and looking for some advice, I've noticed for a few months that it seems to be lumpier than normal when idling, enough to shake the car and make you feel sick. This only happens when the engine is cold. When the engine is cold it is also down on power, it's like the car is running on tar, it's gutless for the first few minutes...
So the car is at the moment averaging about 37mpg whereas it always normally achieves about 48mpg.
I've had a look around on the forum and I guess it could be either coolant temp sensor, or the MAF. I can test the MAF at the weekend with VAGCOM, I'll be able to read any fault codes then too, just looking for some opinions on what I should be looking for if you all don't mind
