Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
@ AndrewJB Have you changed te mounts on the Cupra 280 as well? How was the daily drivability with the LCR? - a lot of vibrations?
There is a very small amount of vibrations on a petrol, on a TDI it's another matter.
Regal Autosports are BFI importers but when I asked they had none in stock mainly as interest was quite low, this was some time ago however. Are you planning on getting the full works or just the inset?
Well if you wait till Friday I can let you know about the superpro one
What are you installing it on?
The best MQB chassis aroundmk7 golf admittedly but were all EA888 anyway so its the same parts
So what did you end up getting? The whole motor mount set including the torquearm bushing?
Sorry, I still can't make it only with the pictures.
How is the neutral and reverse?
Yes full kit, as per the link about. Basically 2 big ones instead from above and then the bottom one that needed the subframe removing! I'll take some more pics installed tomorrow.
The vibration really is extremely minor I can't believe how little it is so neutral and reverse are fine.
Sorry mate instead of "instead" in the post above it was supposed to say "in the link" bloody autocorrect! I can't find it anywhere else but that ausie site which doesn't help too much. I'll put some more pics up today of it in the engine bay.
You could always ring shark and ask if they can supply them?
So how's it been with the full mount kit? Regretting yet or smooth sailing?
