Deej's mk1 LCR 225
rossi46
495
Kent
Just placed a naughty order with awesome too... Should come this week.
Forge short shifter front to back and side to side.
42 draft shift bushes.
Ecs red coil pack conversion plate with 2.0 tfsi coil packs and iridium spark plugs.
Ecs magnetic sump plug.
911 oil cap.
Newsouth power gasket.
034 motorsport street density dog mount kit.
Can't wait to start fitting it all.
Stage 2 mk1 LCR amd tuned 294bhp
D.K
LCR 225
Oct 24, 2007
6,408
se london
It's a bit hard to tell fro your picture but all I did with mine was to bend the mounting bracket for the strut over a bit
rossi46
495
Kent
Cheers DK il have a look at that as an option. Scared to drill my turrets though lol. You use stainless m10 nuts bolts washers etc?
Got my Awesome delivery through today! Lots to be getting on with!
rossi46
495
Kent
So moved on a bit with the build today. Need to fit my ECS adapter plate and 2.0tfsi coil packs. This meant tidying up the rocker cover and relocating the n249 valve and vacuum resevoir to get rid of the awful metal bracket over cool packs 3 and 4.
rossi46
495
Kent
Clearly a mess before..
rossi46
495
Kent
So I re ran the vacuum hose from the manifold and extended it and mounted the n249 back out of the way on the fire wall. This's meant re running the loom for it. Then extending the other hose to the vacuum reservoir which I mounted on a hole on the battery cover.
No fault codes and still 22psi boost on a quick test drive after.
rossi46
495
Kent
Today I thought id get the s3 strut brace on. First up was fabrication to get the bonnet strut to fit...
And it fitted nicely....
rossi46
495
Kent
Then the scary bit. Mark the holes and drill the turrets to mount it....
rossi46
495
Kent
A lot of patience but no hiccups and the finished product....
Well happy!
rossi46
495
Kent
Thanks man.
Today I wet to put on my 034 street density engine dog mount on. Took mine off to find that it already has powerflex poly bushes in it.
Changed them over and tested them both and 034 kit moves loads from torque whereas the old one does not move at all. so I cleaned it up and whacked it back on lol.
Stage 2 mk1 LCR amd tuned 291bhp
http://www.seatcupra.net/forums/showthread.php?t=366267
rossi46
495
Kent
Still have a few bits to do that are sitting around waiting to be fitted over the next few weeks:
Forge short shifters
Eibach front and rear arbs
Magnetic sump plug
911 oil filler cap
Full service which will also include injector o rings and front drop links.
While inlet manifold is off may even get it polished to match the charge pipe.
