since my LC has been out of warranty i've had one problem after another.
the latest is the diagnosis/excess of pollution light. this came on the other day.
however, car still drives as per usual, and i've checked the oil etc and they are all fine, the exhaust doesn't sound any rougher than usual either as best i can tell. also the excess of pollution light is not flashing - it says in the manual that it should.
I did have bother with the temp sensor light flashing/beeping on startup a couple of months ago (as soon as the cold weather started) which i ignored for ages as I was confident it was nothing other than poor quality parts from seat: I had two temp sensors fitted under warranty after they failed! A quick clean of the the prongs and a tiny amount of coolant later and the problem is gone.
don't fancy giving the seat garage £60 to run vag-com if it is just another annoying fault on the leon (like the temp sensor).
just wondered if anyone else has had this light come on but the car seems fine???
I'm hoping to ignore it much the same way as i did the temp sensor light (at least the pollution light doesnt let out a terrifying beep)
