I think basically you will be happy with which ever ones you get. AS there all pretty much the same, nuespeed ones IMHO look better being red.
One think to point out some say you have to have an after market zorst to fit them. Im sure the nuespeed ones go straight on tho?
Ive been in an octy with FSD's. If i had the choice again over my FK's i would go for teh FSD's every time!
i am getting a BF zorst next year once my pennies have mounted up, I am not getting coilovers as i cant afford to lower the car due to the amount of spped bumps around my area, so my plans are to get the following;
Koni FSD's
Neuspeed ARB front 25mm
Neuspeed ARB rear 28mm
Audi S3 Upper strut brace
I think this will improve handling a great deal but without lowering the car, although i would like to lower i cant risk it
I have 22mm on the front and the 25mm on the rear!
There is just the right amount of bodyroll offering lots of grip and easy control when you run out of it!
For everyday use i can't fault my setup!
