Oct 12, 2005
1,013
I have a rattle on the passenger side inside door hanle. I am not with the car at the moment. Was just wondering if its easy to pull apart. The rattle is more evident when you squeze the handle.
Very easy to pull that section apart. It all just unscrews or levers apart...
I had the same rattle traced it down to just behind the door release lever. I just used P profile draft excluder on the mating surfaces of the plastics to stop the rattle:)
door card will need to come off but its only a few screws then ul see the handle mechanism the cable is tapping against the door membrane a bit of foam or sponge between the two will stop that mate!
the handle itself doesnt unscrew or leaver apart its part of the doorcard so dont try that :)
