Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
I had the door card off earlier, I wish I counted the pins now lol is that the only difference just 8 or 9 pins?
I've got the fabric piece off and I have access to the top of the actuator. If I can find a long rod with a tiny hook on the end, I can open the door. The cable has come off on the actuator end but it's impossible to get it back on because the hook is a rubber thing that has to go in sideways so it can only be reattached with the door actuator removed. Tomorrow my mission will be to find a long wire or stick with a small hook, so I can pull on the inside door unlocker thingy. Come to think of it, the other end of the cable has a hook, I'll see if that fits in the hole.I had to buy a tool to remove the the tool bolts
Crv-m8
I don’t know how your going to get in the back door to tell the truth
You need to get the top fabric panel off and that’s it really to open the door
You can do that with the door closed no problem
Remove the plastic strip in the middle first and then remove the fabric section
Just take a bit of force and trim removal tools
Just get creative with a wire coathanger perhapsI've got the fabric piece off and I have access to the top of the actuator. If I can find a long rod with a tiny hook on the end, I can open the door. The cable has come off on the actuator end but it's impossible to get it back on because the hook is a rubber thing that has to go in sideways so it can only be reattached with the door actuator removed. Tomorrow my mission will be to find a long wire or stick with a small hook, so I can pull on the inside door unlocker thingy. Come to think of it, the other end of the cable has a hook, I'll see if that fits in the hole
	How ?? I’m having this issue can’t get door open both my cables still attached though ?Done it mate, used the hook from the door handle side of the cable. In the dark with fricking phone LED for light lol
P. S. The tool required to undo those star bolts is called a spline bit, which has more teeth than a regular torx bit. Ordered one on Amazon, should get it tomorrow. Then I will be having a second attempt at changing the lock.
