Glad you are really happy with the Custom-Code DPF-OFF. I believe that we have spoken to you about this not too long ago? As mentioned on the VERY early stages of testing and R&D there were several different tunes on the DPF equipped cars to eliminate all problems and lights that are expected with the DPF and regeneration. The light that is on will be caused by something else. The tuning does NOT delete ALL sensors; the ECU still uses the lambda and temp sensors (EGT) so if a fault shows with one of these units then it will throw up the light.
Do you know who? Coming up to 50 cars and over 30K mileage on the original test cars. We have not had any issues come up nor had a customer report a DPF fault or light coming on.
Hi M0rk, don't you think that what you are saying is somewhat unfair, as you don't know the cause? It would be like having your car remapped then a coil pack fails with you saying it is all down to the map, do it again properly?
If you have any questions please feel free to call or PM
JBS Team
