Dump valve Question
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
btw, a K03s can be silenced or un silenced. So if it doesn't have the big lump on top, it doesn't mean its not a k03s.
Pidge
I
Oct 11, 2008
76
Aberdeen
Just out of interest how quickly does it drop back to 12psi after its spiked? If its more or less instant it could be that big black reservoir on top of the rocker cover pissing it all out due to a boost deviation? I *think* thats the n249 doing what its meant to :confused:
Id be checking all vac lines and getting rid of all the unneccessary crap under there first bud ;) (n249 bypass at least and possibly the n112 aswell but youll need some resistors to do the full job)
My car spikes to ~20-22 psi which it holds for just over 1000rpm then tails right off to 10psi by 6k and slightly under that at 7k. Mines meant to run 200-210bhp (previous owners quotes) but im pretty certain its well under that. Maybe 190-195 at a push, im happy though as its running really well for the first time since i got it! :thumbup:
Just the limitations of a standard exhaust, smic and TIP :thumbd:
M87NER
MATNER
Mar 11, 2007
1,338
Stoke-on-Trent
Are you sure its 223bhp? is it proved from previous owner? as thats fair high for a standard k03 turbo... what other mods have you got? what map has it? 19 psi sounds right and if it peaks 19psi and holds it to around 4.5 5k then tails off to 13 psi thats normal for a k03 turbo
yeah 223 @ the flywheel i have a printout
mods
k03 standerd turbo (i think)
green dynatwist filter
sports cat & downpipe
full supersprint exhaust
jabba sport stage 2 custom remap
front mount intercooler
just done n249 mod
forge 007p dv
silicone vac hoses
and no it peaks at 19 psi then about 2 seconds later it drops to 12-13 psi even with the n249 mod
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
mods
just done n249 mod
forge 007p dv
silicone vac hoses
that sounds about right with those modds...its the all famous lottery!
