prc said:a cracked version will still cost over 1000 euros with only some of the checksums
P,,,cough,,,2,,,cough,,,P
there's everything you named and more,,, not that I'm saying you should do something illegal,,,
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
muddyboots said:I'll bear that in mind Carlo![]()
muddyboots said:If I get caught I'll tell them a hairy Italian bloke told me to.
muddyboots said:Well being a software engineer, I have a good hex life.
You don't even deserve your coat for that. You can go freeze out in the cold tonight.muddyboots said:11111111 - 000000001111111111111111
(or F - 0FF in hex)
Great, thanks for the info.yellowperil said:Going back to the original question, yes the ecu-flasher will read and write files on the edc15 ecu well enough. If you want to read your passat though you will need one of the vag direct ecu leads, most of these cant be read over the OBD port.
As for tuning files DO NOT use anything from the DVD that comes with it, i have seen some of these files, badly tuned and poorly listed, one wrong file could screw your ecu.
If you need files buy them from a tuner made to your spec.
Hope this helps
