My exhuast is causing major issues and its winding me up!
Keep getting Bank 1 Fault. (Running Lean) Keep getting low boost 5-7psi aswell and the exhuast sounds loud!
The Exhaust after going to SEATtoday seems to be different size at the joins so they have put sleaves in?!
First join seems to go from 55mm - 60mm and the second join 57-63mm they want to cut the system apart re-weld and put on industrial exhaust clamps so it never blows or comes loose
I'm taken it friday to be done but should i have such problems?
