skoolz
My Car Background....
funny coz I seem to have a similar problem on my SEAT ALTEA 07 1.9TDi. First about a month ago the interior light fuse went 7.5 brown one and I replaced that a few weeks ago. Then it went about a day or 2 after. replaced it and that wnet again. So I replaced it with a 15 amp fuse. Then the Inition lights fuse went a few days after and the cr would not start. I replaced that with a like for like 10 amp and car started but now the Drivers airbag light stays permanantly on. The start fuse went again the next day. Replaced that with a 15 amp but I think i have a short somewhere around the ignition and steering as the first time the start fuse, I heard the fuse go as I started the attempted to start the car. Also when the interior light fuse went for the second time, it happened whilst i was driving. The interior light was set to the permanently on position but the lights weren't on and whilst I was turning the steering wheel it came on briefly then it went of and when I checked the fuse had gone. Also importantly......... before fuses started going...a couple of times, I had instances where the car remained on after parking, switching off the ignition and pulling out the key. It would only switch off when I turned the steering wheel.
I know I have a problem but was hoping to get some experienced diagnosis/knowledge as what the issue may be, info from others that may have experienced similar, what was to resolution and outcome etc? Please Help? Will a VAGCOM be able to indicate what the issues are? Will I need a new ignition and probably coding....what are the costs of that?
I'm worried..
No help was received regarding the above post, now the engine emission control system light has come on so decided to purchase myself a VCDS 11.11 diagnostic kit and ran a diagnostic which returned the following errors...bearing in mind that i took my car earlier this year to the dealers, with my above issue and £50 after they say the diagnostic returned nothing:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 021 LN HW: 03G 906 021 AN
3 Faults Found:
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Mileage: 79967 km
Time Indication: 0
Date: 2000.00.00
Time: 09:37:12
Freeze Frame:
RPM: 882 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.67 V
Bin. Bits: 00101100
Temperature: 5.4°C
Bin. Bits: 10110000
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.24 V
Bin. Bits: 11101100
Bin. Bits: 11000000
(no units): 0.0
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 88559 km
Time Indication: 0
Date: 2000.00.00
Time: 20:08:51
Freeze Frame:
RPM: 1050 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 64.7 %
Bin. Bits: 00101100
Mass Air / Rev.: 335.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Readiness: 1 1 0 0 0
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004626229
Coding: 01880F2700041000431E00000000000000007F0B5C4000
Shop #: WSC 06402 785 00200
VCID: 6CDDB5144F90E8E
Subsystem 1 - Part No: 5P0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 211206 022 0601
Coding: 00056208
Shop #: WSC 06402
6 Faults Found:
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 168
Mileage: 88342 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.00 V
ON
OFF
OFF
OFF
ON
02399 - Control Circuit for Terminal 30 for Interior Illumination
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 133
Mileage: 80040 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Voltage: 12.75 V
OFF
OFF
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 170
Mileage: 88559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.00 V
ON
OFF
OFF
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 170
Mileage: 88559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.00 V
ON
OFF
OFF
OFF
OFF
00059 - Terminal 30 for Interior Lighting
Freeze Frame:
Fault Status: 01101100
Fault Priority: 5
Fault Frequency: 254
Reset counter: 133
Mileage: 80037 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.15 V
ON
OFF
OFF
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 170
Mileage: 88559 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.00 V
ON
OFF
OFF
OFF
OFF
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
VCID: 74EDAD7417A030E
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
014 - Defective - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 F HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1132
Revision: 32008001 Serial number: 00000526969017
Coding: 0000560
VCID: 3B7F46487A7EBF6
1 Fault Found:
00944 - Heated Exterior Mirror; Passenger Side (Z5)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 29
Reset counter: 173
Mileage: 86028 km
Time Indication: 0
I'm sure a lot of our Forum users including myself could really benefit from any assistance in how to go about resolving these faults without braking the bank, myself included.
Any help will be most appreciated guys:cry::cry:
First thing to do is save a copy which you probably have to post it here!.
Then go into each module and clear fault codes. Run check on fault codes again see if any reappear. If not then go for a drive and rubn fault search again.
Quite a few codes are one offs and nothibg to worry about - note quite a few of the faults which may not be related occurred at the same milage.
( i find doing a general fault clear doesn't work anymore and you have to go into each control module)
Cheers CripD, did and restarted and drove and engine light came back on. Ran the check again and got these 2 codes...
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 88828 km
Time Indication: 0
Date: 2000.00.00
Time: 16:15:08
Freeze Frame:
RPM: 819 /min
Speed: 0.0 km/h
Load: 0.0 %
Duty Cycle: 95.1 %
Bin. Bits: 00101000
Mass Air / Rev.: 245.0 mg/str
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 136
Mileage: 88828 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 14.45 V
ON
OFF
OFF
OFF
OFF
Any ideas on how I can resolve these??
So It's now been two years since I started experiencing electrical faults with my SEAT ALTEA TDi 1.9 07. Started off with the interior lights 7.5amp fuse blowing so I made do without them. Then after months the car started blowing the dash/ignition power 10amp fuse which would completely cut off the car. This would happen so intermittently but seemed o be always linked to a moment when driver was maneuvering the steering. Replacing the fuse and continuing sufficed for while. I made do with this for time and finally a point came when that happened and a replacements fuses where blown the instant i turned the steering wheel leaving me stranded. I had to be towed home by the AA. I made inquiries with various experienced electricians but none had heard of my issue and quoted me 30-40 and hour labour charge to diagnose it but couldn't say how long so that could go one forever. As we have two cars in our household and I don't use mine to commute to work, I made it a point to find the fault myself and rectify it. I removed the steering housing and looked around ignition controls for any loose wires etc, nothing. Finally today I removed the dash bottom housing and inspected along the steering column and noticed the Thick cable trunking with all the electrical cables from the engine/battery etc into the car, was wedged just above the pedals but cable tied close to the steering axle joint which is steel and square like. The rubber trunking section above the steering joint had snapped and upon snapping the cable tie and pushing the trunking away from the steering I noticed that where the rubber had snapped, there were about 3 exposed (bare) wires. Turns out due to the trunking being close (pretty much on) to the steering joint, every time maneuvering occurred, the friction scrapped the trunking first snapping the rubber trunking, then scrapping the wire plastic covering exposing the wires. Then every time the steering was maneuvered, contact occurred between the steel steering joint and one or more wires creating a short which blew the fuses etc. I have now pushed this away from the steering and covered the trunking again. Problems solved one and for all. Al error codes erased with VCDS and re-scanned. No Errors..... SWEET!!!!!! Pennies in my bank.
So please bear this in mind if you have steering related electrical short circuit issues.
Excellent post. You deserve some sort of prize for sorting this out and posting the solution on this forum.
