I know this is an old post but wondering if anybody could point out the pipe that caused this problem, preferably Mr OCD??
I have the same fault code and initially checking the pipes (visible) and vacuum hose I can't see any splits. Would be greatly appreciated if could get a picture of it or a pic of about where it is located.
Don't have a picture to hand but if you remove the cover plate attached to front of inlet manifold it is one of the vacuum pipes that goes down front - side of engine.
It will be noticeable as soon as you remove the inlet plate... Also check all the vac and breather hoses whilst it is apart.
Had the same codes. Took my car down to a local,vag specialist last week. Found the split pipe under neath the throttle body(part of the pcv system) took myself 10 minutes to change and the pipe cost around £17. All performance and economy is back also have done over 100 miles and no codes. Can get you part number if you want?
Thanks for the feedback Wesson picture is very handy, I haven't had change to remove any parts tonight to get access to pipes to find any splits as weather is really bad (raining, as usual) so will look tomorrow, of it turns out to be this pipe a part number would be great :)
Its alrite mate. the part number is 06A 103 221 BK. Also whilst your there check the crankcase breather pipes. Ones Y shaped and connects just below your diverter valve(or dump.valve)
