Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,872
Guisborough
www.vagcars.co.uk
Well some of you know I had my car on VAG-COM after my diagnostic light appeared and I got an error but I couldnt quite remember the exact wording. Well my own interface from Ross-Tech arrived today (took 48 hours from USA) got it all installed and plugged it into the computer and the full code is:
17831 - Secondary Air Injection System; Bank 1: Insufficient Flow
I presume as said before that this is just a problem on start up and warming of the CAT but I'd just like to confirm that. Also when doing an auto scan I get one other error that doesnt show up in the fault codes section, that error is:
00779 - Outside Air Temp Sensor (G17) 30-10 - Open or Short to Plus - Intermittent
Anyone know what's causing that one, is it the curse of the dreaded outside air temp sensor?
Im not 100% sure but the second fault code would make sense to be the outside temp sensor?
David.
Yeah in the bottom of the n/s door mirror. Very common fault. The new sensor fits into the bottom of the mirror housing and the loom runs into the door.
00779 - Outside Air Temperature Sensor (G17): Open / Short Circuit to B+
[edit]Possible Symptoms
In the Instrument Cluster you see dashes (---) instead of a temperature
[edit]Possible Causes
Wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster: Open or Short Circuit
[edit]Possible Solutions
Check wiring between Outside Air Temperature Sensor (G17) and Instrument Cluster
Check Measuring Block Value
