fans have to be manually switched on from inside the car
Marco20VTurbo
hi all was wondering if any one recognised this Leon
its a 2001 reg KX51 BVU Candy white with black bonnet and chequed roof
i am going to do a deal with it and my fiat coupe 20VTurbo on sunday
he said the temp guage sits at 90 degrees all the time and this is a common fualt and the fans have to be manually switched on from inside the car when sitting in traffic,. is this a common thing and is it a simple fix.
not sure how to put pictures up on here so will do when i figure it out.
also can you guys give me a couple of pointers to look out for too?
thanks
marc :)
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
Sounds like the water pump has possibly failed, although I guess it would rise above 90 if it had. How many miles has the car done? Has it every had a water pump replaced? Cambelt? Been regularly serviced? When did is last have an oil change?
Fans could be a temp sensor / switch failed I suppose, but rather than wiring them up to the inside it would have just been easier to fix!
Marco20VTurbo
does sound strange.
the car has done 83k and water pump and tensioners etc was done 3k ago so at 80k
i can have my mate look at it but the fans dont come on automatically you have to switch them on. which is strange i think could it be a sensor. its had an intercooler fitted to the front too
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
has the front mount been bodged and had to be rewired to new switches inside , rather than connect original back up ???
unless the previous owner didnt trust the temp sensors and had it rewired to manual switching , hense as soon as the temp moves on they go >>>
as for pictures , you need to use something like photobucket and post the links up
think you need some more posts first tho
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
You are talking about the radiator fans, I assume, not the cabin air fan. Just checking . . .
At least two faults, possibly more.
Temperature gauge - well, it should sit at 90 all the time, but the fans should come on to keep it there. If it doesn't move at all, the coolant temperature sensor is the prime suspect.
The fans, though, are controlled by a separate thermoswitch in the radiator. If the fans don't come on at all, then either the thermoswitch or the fan control module are at fault.
Does the car have air conditioning fitted i.e. an air cooler for the cabin? If so, the fans should come on at low speed whenever the air cooling compressor is on. This is a well-known failure point, the fans themselves have resistors fitted to give the low speed running, and these fail, requiring new fans or an external resistor to be fitted. If left untreated, the fans cycle between high speed and off, and eventually burn out.
BUT, you say he can turn the fans on from inside the car, so they still work.
How does he manage to turn the fans on manually? Has a separate switch been fitted??? How long has it been like this? There is no way to do this on a standard car, so this fault has been present for some time, if it's been bodged up like this.
I'd be very wary of this car, it's almost certainly been running too hot and could easily be about to fail. You can't control the engine temperature by just switching the fans on when you are in traffic, especially with no termperature readout.
What engine is this? Petrol, diesel, 1.4, 2.5???
Marco20VTurbo
hi mate thanks for the info
the car is the Cupra so 1.8 T engine. the switch is to turn on the rediator fans when the engine is getting hot so when sitting in traffic.
its got a switch in the cabbin to turn these on. after market i suppose.
Marco20VTurbo
ok spoke to him
the guage works
the switch has been on there for 3 weeks.
sheffboy
avoiding potholes
May 25, 2007
655
Get some pics up mate. I'm Intrigued.
Sign up to photobucket (free) and upload the pics from your computer than copy the image code to your post.
not many LC's about that have been sprayed candy white. Does it have the Cupra R front bumper?
Marco20VTurbo
it does mate
its nice to be honest am worth fixing if it needs done
i have an account will try and put them up
Marco20VTurbo
me too
one of the temperature sensors went apparently
you think it could be a quick fix so long as it doesnt over heat yea?
i will get my mate to have a look at it he as a VAG specilist
Marco20VTurbo
true likes i know what you mean.
my car isnt exactly imaculate tbh needs some pits and peices sorted that he knows about so i dont mind having to do a little bit of work so long as i dont have to pay hundrends of pounds
sheffboy
avoiding potholes
May 25, 2007
655
I've seen this before. Can't remember the guys username though.
He's deffo been a member on here.
Marco20VTurbo
ok i understand it now.
the fans stopped turning them selfs on so he has ran a wire from the switch into the cabin to turn it on when and if the guage goes any higher. but it turns it self off when the temp returns to 90 again so back to normal. so it does work in a way he has not had a chance to take it to the garage
