Fans running on 2.0 CR FR
jellybabybandit
170
Anyone else with a 2.0 tdi have their fans runnung quite a bit after you stop and switch the engine off ?
mine seem to run quite a bit which would suggest its running hot which shouldnt be happening in the autum/winter
DEAN0
Old Git
Feb 1, 2006
5,297
307
Preston - UK
It's normal if you switch off the engine during a DPF regen cycle.
Is your idle speed sitting at around 1000rpm rather than the normal 800rpm when you switch off ?
jellybabybandit
170
Funny you should say that there is always a burning rubber smell when it happens so prob is the regen
Cheers guys
Nath.
The Gentlemans Express
Jan 1, 2006
8,620
16
EASTLEIGH, HAMPSHIRE
Deffo sounds like a regen. You may hear that the exhaust note is a little gruff on a regen too.
Just take it on a motorway run for 5 mins to finish the regen cycle. If you switch off mid regen too many times it may flag a DPF light.
