200bhp
I scanned my car when I serviced it.
It has an LPG convesion which I think needs servicing / remapping.
It has 2 fault codes (and I cleared them a while ago)
16716 - knock sensor 2 - G66 Signal too low P0332
17536 Bank 1 Long Term Fuel Trim (MUL) system too lean P1128 Intermittent
Am I right in thinking the knock sensor is faulty and the second one is probably caused by the LPG ?
Yes on both counts.
You could try cleaning up the electrical connector on the knock sensor first (if you can get at it). If replaced, correctly torquing the bolt is critical.
