There is an option on the Infotainment screen setting menu on my TSI FR to have the screen go blank after 10 seconds and only come on again when you move your hand towards it. You probably wouldn't use it while in SatNav mode but if just listening to the radio (or audio books like I do) you don't really need to see a display all the time.
The problem seems to be that the feature works fine when set but resets itself every time the ignition is switched off.
Any body else had the same problem?
