You know there are two adjusters behind each light? From memory the inner one does vertical, and the outer one does horizontal.
Other things to check, does the headlight height adjust motor work on both sides?
Have you broken the reflector, so that it's no longer attached?
Simon.
As far as i can tell both of the reflectors are attached and the "adjuster" motor works on both sides. It just seems odd that one side would screwup up.
When you say that the headlight has two adjusters, do you mean that the white toothed dial moves the light horizontally and the hexkey socket on top moves it verticaly:think:
Nope. They both do the same thing. There's one adjuster on the inside edge of the headlight, and another hidden under the wing on the outside of the headlight. You operate them both with a long hex driver held vertically, down through the carefully provided hole.
Simon.
I believe i have found the problem. After tinkering with the adjuster on the rear of the headlight the motor will kick in if you tap it. Whiped the motor off and cleaned off all the gunk and found a crack running down one side, so a new on is on order (£22.50 + VAT part 1J0941295B)
Now with any luck this should sort it, which will leave me enough time this weekend to retro fit the rear electric windows.
