It's not split - I've done over 20,000 miles with it. It's quite heavy duty. The cork was there to stop me piercing the ducting on the peg that's there while I was installing.
how did you fit the ducting inside your airbox mate. cheersDPJ said:4" from B&Q (<£6.00) - but now feeding my modded air box instead of the RamAir
so where do these battery relocation kits come from ?Feel said:Part number for Green Panel Filter for LCR is "Green Panel Filter for LCR" - just ring/pm Bill. There's a recent thread in the Badger 5 section with prices etc.
If you order the 80mm feed you can squeeze it into the standard airbox hole, and it makes it a nice tight seal, although I've had better results from making the hole bigger.
jason said:so where do these battery relocation kits come from ?![]()
NeilC said:You managed to find a route down to the fog? Pics would be nice as im doing mine tom. At first glance it looks like there's too much samco in the way, suppose i'll have to take the battery out and have a look.
Did you manage to keep the battery cover on?
How tight is it? 80mm tight or 102mm tight?![]()
NeilC said:My ability at proving phil wrong didnt go too well.
Theres no battery cover in the pics but thats just cos i've lost it.
Picture of it poking outredface
to prove i werent faking it.
Bizzarely where the fog fits in there is an 80dia tube sticking out which nicely intererence fits on the end of the tubing. I cable tied round to be extra sure tho (not shown in pic).
You wouldnt be able to get a 100dia tube down there without denting the bit that goes round the pipework down to about 80dia, and you'd prob need to take out the offending intercooler pipes to get the dent in the right place so not worth it imo.
Wether or not this is better than the other route to the left of the headlight is questionable as it still bends 3 times and is a similar distance. I couldnt log as there are police and drunk drivers everywhere (the ones doing 20 in a 60 to be inconspicous but leaving there full beam on)
Anyway those arent dead flies, it's so clean its sparkling in the sun![]()
Empi5 said:Neil, pictures arnt working
