danston
after hard consideration and reading LOTS of post i decided to try a China aftermarket unit.
so far I'm very happy.
a few things to consider on fitment. the guide in FAQ is Very useful and help with removal of old radio , had unit out within 5 Min's.
i routed cables down through dash, along bottom of glove box and out via side trim up onto to of windscreen, took no more that 10 Min's and no cable visible. also area behind trim is good for storing excess cable. i drilled small hole in glove box and put the USB connector in there.
all cables fitting very well, i pushed OEM block back through dash and sat above unit to connect new wires.
the only problem i found was where the SD cards slot into unit there is a mental box that wouldn't fit gap so i had to trim the internal dash to suit, very easy but wouldn't of been my first choice of things to do as its meant to fit.
Also remember to remove CD screws before fitting
(will update with pics when I'm able to post them.)
Dan
Dan
