Hi guys I'll be fitting a new milltek decat and down pipe and non res cat back milltek system this weekend to my Cupra r and just wanted to see if there was any tips/issues when changing I should know about? I have only done an exhaust on my old Cupra before not Cupra r.I'll be buying a new gasket from turbo to down pipe and the rest comes
With the system regarding the lambda sensors where do they go? Should I heat the bolts up on the downpipe/turbo before removing to avoid snapping the studs? And along with this exhaust a turbo intake pipe forge dv and panel filter should I require a stage 1 or 2 map? All Be it I'll probably use r tech or badger 5 as I have heard nothing but good feedback from both
Any advice is much appreciated cheers
