This is a link ive also seen as many others but none clearly show or say that you are ment to fit screws into the two central supports where the V's were. If you cut them down so fare your not left with a flat part to screw through??
^^^^^what's with the.
What do you expect. the LCR splitter is exactly that, a splitter from a LEON CUPRA R. it is not meant to be fitted to an IBIZA. It is a modification.
If you can't figure it out then you don't deserve to have one on your car....................
I have one for sale if anyone wants it for a tenner It's like new.
iam after one you any where near hampshire???
Mine used to be on a LEon and the Vs are vut down a bit but now they are just kind of there look a bit silly. Shall i cut them off anyone think?
i wouldn't cut em down completely aimez...if you're worried about it being forced off by scraping then don't (as long as you secure it enough)
It is not secured on at the V point at all just the usually screws got to do something it looks a bit silly as it is.
how will it sit closer if they cut off?
