knight85
Money spending clown
Dec 30, 2008
2,222
South East
Hi all,
Literally just arrived at work at the TCS light is on full time and then 1 minute later the coil light is flashing
I know this is a common problem and is related to the brake light switch...i know I have a brake light out and was going to change it this weekend.
I presume the brake light switch will need to be replaced?
is it ok to drive home with the car like this?
I had the same issue as you previously.
Brake light switch should solve all of the above. Unfortunately in my instance I had to get the ECU reprogrammed or something like that !! Cost me £65 anyway but yours by the sounds of it will just be a brake light.
So either way it shouldn't be an expensive fix.
lovely thanks - do you just replace the brake switch then?
I have just checked my brakelights - and th eonly one that works is the top -middle one
