robjackson
49
Whats wrong with it? How do i sort it?
10 Faults Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-10 - - - Intermittent
17811 - EGR System: Regulation Deviation
P1403 - 35-10 - - - Intermittent
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 35-10 - - - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
16585 - Injector: Cylinder 1 (N30): Circuit Malfunction
P0201 - 35-10 - - - Intermittent
16587 - Injector: Cylinder 3 (N32): Circuit Malfunction
P0203 - 35-10 - - - Intermittent
16586 - Injector: Cylinder 2 (N31): Circuit Malfunction
P0202 - 35-10 - - - Intermittent
16885 - Vehicle Speed Sensor: Implausible Signal
P0501 - 35-00 - -
No idea - sorry mate - doesn't look too healthy though :(
If you hit the edit button on your first post, you'll be able to remove your VIN :)
i work for peugeot and when all faults like that all over the cars electrics happen its usually the ecu or bsi thats the problem, however this is a seat and so that prob will be wrong!
Hope it is ok!
(would deffo take it to the dealers!)
Andy
the 1.2 has a history oif throwing the timing chain a few teeth and making the valves out of time with the pistons, this can be caused by a broken chain tensioner
this I think throws up the last fault code that you listed and hopfuly the other ones are affect rather than cause, it also inhibits starting of the engine so as to stop valve damage
the very best of luck to you with it
also consult a dealer for a 50/50 repair job as seat know this problem happens and have paid out after earrenty has ended many times on this timing chain issue before
There's a few sensors there with implausible signal faults. Its a wild stab in the dark but could they all be on the same earth stud which is now making dodgy contact?
Can you please point me to where i can find more information about tgis before i approach the dealer about the "known issue"?
I did a search and this was the first 3 results, lots of people on here have deffo had this problem
either causing rough running or a failure to start cos it's jumped lots of teeth
http://www.seatcupra.net/forums/showthread.php?t=108848&highlight=1.2+timing+chain
http://www.seatcupra.net/forums/showthread.php?t=107415&highlight=1.2+timing+chain
http://www.seatcupra.net/forums/showthread.php?t=105197&highlight=1.2+timing+chain
ring the dealers and ask about the 1.2 timing chain tentioner known fault, I think they were upgrading them as part of a service (sort of a recall)
Right here goes:
Problems diagnosed by SEAT without any fault codes bar what i gave them:
new timing belt/chain, tensioners, and guides
coolent temp sensor
Price of parts - £140
Price of labour - £640 (£80/hr)
Option B
Engine from a mate for £250 (done 15k miles)
fitted by another mate for £100
Total cost inc. paying seat for "diagnosis" £400
Whats the best option?
the resale vale of your car would be *uck all if you change engines but how old/ milage of urs so do you care. If its resale is 4-5 grand ish id stick with seat!
Andy
