Forge Split-R Valve - Question...
Jan 3, 2006
834
East Kilbride
Received my valve and fitted it today to my LC - Thanks to Forge and also SCN for the discount ;)
Gave it 1.5 to 2 turns and all seemed well no rattling on idle and performance seemed fine but with more whoosh! Only when i went to put the car in the garage did i notice the valve had started making the rattling sound.
Tried adjusting it again half turn at a time but its still rattling managed to get it down to a fairly quiet rattle but should there be any at all....?
Scott
RikH
Texas Cowboy
Oct 17, 2005
2,473
Yorkshire
side Q
did you adjust it before you fitted it, or once all fitted with the vac line on the top (well side this way)?
Jan 3, 2006
834
East Kilbride
I gave it a turn after fitting it. First time i started the car it wasn't rattling. Instructions say if it doesn't rattle then give it 1.5 to 2 turns. When i done this everything seemed to be ok. Was only after driving for half and hour it started rattling....
When adjusted it later after hearing the rattling i turned the engine off and loosened the clip so not to twist the narrow hose, and gave it a half turn at a time...
Jul 4, 2006
513
Maidstone,Kent
i am really gutted now cause put the 007p one on and was really disappointed as i couldnt really hear it. is forge the only place u can get it from? none on ebay or anything?
RikH
Texas Cowboy
Oct 17, 2005
2,473
Yorkshire
no no, dont get disappointed the 007p is a proven good valve that EVERYONE had/has
its not standard at all, they have interchangable springs available for them depending on what psi you run your turbo at
majnority of people are still using them, myself included
Jul 4, 2006
513
Maidstone,Kent
yeah i know but i wanna hear it, thats why i was disappointed, but if i got a bmc-cda will it make it louder or do u think i should get a green panel filter? do u have to do anythin to ur airbox?
Jul 4, 2006
513
Maidstone,Kent
i wanna hear the dump though, how much did u get ur new dv for? i am gutted how long has this been out now? yeah i can hear the turbo spoolin up more at the more i wasnt the whoosh lol
Bogwoppit
1,085
Lincs
If you put an open cone filter on your car, you will hear it dump.
If it has been mapped the dump noise will be louder. Also if you bypass your N249 valve the dump noise will be louder still.
cupra r rick
gav where u been mate??? really should get on here more as its clearly your missing out n spending your hard earn money in the wrong places :p
