fourtwofive ibiza daily project
Jul 4, 2007
1,674
bristol
yer great new! and i am loving it used a tank of fuel already.
think we did get to the problem of the timing pull basicaly when my engine was being rebuilt the guy that built it could have got the cam to cam timing out by one tooth.
becuase when i first ran the car the cambelt was a tooth out which implys the cam to cam could be one tooth out also. hence we loosend cam belt put that right to clear fault codes.
phil had the same issue so its looking like its that. im not mechanic so dont really know what to do about it. lol
but its all just guessing at the moment but im loosing 20 bhp because of it! going to sort out intercooler first.
Jul 4, 2007
1,674
bristol
no we dont know for sure yet as i need someone close who can tell me for sure if the cam to cam timing is out. so yes could be a tooth out but runs a steady power and is safe. its an easy mistake to make.
Jul 4, 2007
1,674
bristol
had the head apart when engine was being rebuilt for new valves and seals. is it an easy job to reset the timing. is it a proper head off job?
im really crap with engines not my thing and dident get involved with the rebuild. wish i did now
Jul 4, 2007
1,674
bristol
sweet thanks for the advice mate im hoping its not out. bill loosend the knock sensors so could have fixed it. need to do logs to confirm.
Jul 4, 2010
2,170
Cambs
Yeah thats the best place to start, thinking about it you would only need to loosen the inlet cam to adjust it rather than both cams. Good luck anyway mate.
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
Happy to hear you got the hybrid on mate, so how much of a difference is it then to before?
Ive already got a grin on my face and you aint replied yet LOL, going to put my hybrid on soon.....
Jul 4, 2007
1,674
bristol
hahaha its a totaly different car all together than the k03s setup i was running. its a huge difference just spools so fast early and holds boost all the way to the redline.
im glad i whent hybrid insted of bt just because of the money really.
its just what to do next got the power just need to focus im handling and looks now.
put it this was i cant stop driving it normaly i would take my slow eco car to get to work but i just cant stay out the cupra. ear to ear smile every day...
R4cup
Beef NO Burger
Jul 28, 2006
1,757
In the garage
Thanks for exciting me even more now :drool:
Jul 4, 2010
2,170
Cambs
Hello mate few tips on fitting the cooler.
First of all a pic of the bracket..
You will have too mount your rad further back if you want some bumper left and then move the bracket back using washers/spacers ect (only needs to go back a few cm)
It will be best too mock fit the cooler 1st too see what you will need to trim off, it will be obvious.
Heres a pic of the stuff I cut off, not too much.
Here is a drawing of the pipework you will need TB side as its hard too see.
I also used the braces I cut off the slam pannel as brackets underneath..
This pic should give you an idea of what pipework you will need turbo side.
Hope this helps mate
