Refurbished discs!!!
quattroman ... im running 1045s! not 55s!
so thats even worse as the 45 compound should be softer... i would expect the 55s to be more abrasive and being "fast road" they may use this as an excuse... but can they with the standard spec 45s?!
another note to note.... today i fitted new pads and and discs to my bros car.
well i say new discs... the discs were very corroded and scored a bit... they looked like they had come off a car that had been in a scrap yard for about 5 years... they are the original discs (4.5 years old) and i measured them at just over 19mm thick.
toyota say these discs are 22mm thick new and minimum they can be is 16mm.
anyways rather than paying £110 for new discs (from my local cheap trade car place!) they recommend i went to Emsleigh Engineering and had them put on a lathe and had the surface skimmed so it was like new!
well i had this done today and it cost £12 + VAT for each 255mm disc (£28.20 all in)
Peter the guy who did it measured them at 19mm thick each, meaning they are half way through their life span! iv just fitted them with new pads and wat a difference!
so the whole point of the above essay is that if we dont get anywhere with galpher then we could do the above to save the cost of new discs!
this is assuming our discs are still thick enough (wats the min thickness it can be?!
) to do this, otherwise it may not be cost effective/possible!
also like i said in a post above for about £50 i can get my discs grooved, so therefore i may do that.... resurface my discs and get them grooved for about £80.
then again i assume the guy who did matts (smoothUK) can also resurface them on a lathe if he can grove them!
over and out!
