Front Passenger door problems + Indicator Problem
smithsc
271
Huddersfield
Hi All,
I've got a few problems with my front passenger door;
1. When i set off the autolock kicks in but the lock bounces back up (very annoying in traffic).
2. When i open the passenger door the interior light won't come on and neither will the light at the bottom of the door ( i have checked the light in my cousins garage and the bulb works fine)
3. Sometimes when i unlock the car the passenger door won't unlock
The next problem is the front passenger side indicator won't work unless i put my hand in and hold the wires, which is a bit unforunate / dangerous when i'm driving and ideas what this car be????
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
All is passenger door lock related needs replacing/fixing is covered on here.
Last one could be the wiring to it or the actual connector that holds the bulb.
smithsc
271
Huddersfield
so i need to search on the old ebay for for the whole door lock assembly are they normally quite expensive. on the second point i'll try the drivers side connector and see if that works if not guessing its an auto electrician
