fuel pump
jim s3
hi guys this is my first post have been reading threads on here for a while and seems a good place to be to get answers
where is the best place to put a bosch 044 fuel pump in my s3 with gt3076r turbo???
intank one??
keep s3 intank pump and fit inline by filter??
keep s3 intank pump and fit in engine bay??
any help is help thanks
jim s3
hello mate hows the car running with the new turbo any better?
right then its going there then got another problem my car wouldnt start today or yesterday when i turn the key i cant hear the pump prime i also took the fuel lines of in the engine bay and turned the car over and got no fuel out...
so is it the fuel pump relay or the fuel pump??
how do you check the relay??
jim s3
took the relay out and bridged it and the fuel pump started running so fuel pump is ok changed the relay and it still doesnt start, pump dont prime still checked the fuses and they are all okl. what else could it be???
jim s3
no fault codes whatsoever think it might be the battery not having enough voltage to run the pump but will turn the car over fine i will see as the battery is charging now...
jim s3
has anyone got any pictures of how the walbro or 044 are mounted and fittings are needed to attach them to original pipe work???
cheers
jim s3
right guys charged the battery i now have fuel but now no spark what could it be
crank sensor
ignition coil?????
