Gauge Set up....
flashbsd
as far as im aware autometer always have VAC., VAC is vaccum, when your not on boost its usually in VAC area, anythign about 0 is turbo boost, so if i was idling id be about 15 VAC, a blip of the throttle in neutral would make it rise to about -10, and once moving youll be in +
P.s deffo get the -30 to + 30 guage, as once remapped 20 is on the limit so you wont see overboost etc.
hope this helps :) I have ultralites if you wanna see em sometime in action ;)
flashbsd
p.s I regret spemnding 70 quid on the POD, as its build quality is shite, and it doesnt fit properly, if id had seen one like that id had got one and sprayed it! :rolleyes:
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
OK so checked on APEX site, not much difference between Phantom and Ultralite? £1 in price and weight, (which I cant see being much anyway?)
flash why would you spray it? black goes with the cockpit colour? Suppose I could spray it to match A pillar??...
Mike
PS Car is REVO'd and max boost is about 19 PSI when it was RR'd last.
bazza1000
187
Leicestershire
That little pod looks just the part, I might consider getting one now! The nomad holders look good being all moulded in, yet are a little pricy
h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
If you want help fitting it mike, just noise me up ;)
Going to frankinstien on sat mike! see how low i come out at according to them!?! :lol:
HoocH
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Hopefully fit it myself, but if I get stuck I know a few peeps I can 'holler' at...
Where do you lot feed the back light supply from?
Mike
PS HoocH I didn't realise you'd gone nuts with your mods...how long you had the car now? Saw you the other day in dunstable too but was in CTR so didn't beep. lol
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
you want it lit when the dashboard is lit..... so just hook it onto that.
Don't connect it to the sidelight loom
bazza1000
187
Leicestershire
All this talk of boost gauges has just got me to buy one! Brought a Auto gauge phantom one from ebay coming all the way from hong kong. Just need a suitable pod to house it in now, might go for the one mention earlier in this thread unless can get a nomad pillar at a decent price or anyone has a used one etc going spare (put a thread in the wanted section now)
h17och
Sep 1, 2005
3,504
Dunstabubble
mike i got the car in sept 05!
You should still beep, i will always beep back even if i dont know you (i love getting cupra noodle horn) :lol:
i took a feed from the illumination wire goin to the headunit! alot easier! and the ignition live from headunit!
HoocH
