Got my RAID LED lights tinted (few pics)
FILOU
I have found this in a french site... but i don t know if it good and chose the good one ... because tere is a lot !
Can you see ? and help me ?
The first one: 50W
http://www.conrad.fr/webapp/wcs/sto...atalogId=10001&storeId=10001&productId=220954
the second one: 25W
http://www.conrad.fr/webapp/wcs/sto...tId=220922&langId=-2&parent_category_rn=18995
Thanks a lot
passenger side...
drivers side...
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
send that company an email saying you need two 50w 12 ohm resistors! (i think its 50w and not 25w!)
where is everyone?! :rolleyes:
FILOU
Recapitulation :
I need this only two resistors ?
has right and has left?
Can you make photographs of the assembly of resistances? IT will help me
THANK YOU :coolthumb
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
here you go!
put one resistor in each side (passenger and driver!)
eveything you need is in the 2 pics above! :yes:
FILOU
how you made? you welded?
with will resistances the prechauffage die out with the 3 eme lights brake?
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
do u mean how did i connect the wires?
i used scotch locks... those blue things!
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
FILOU... well done fella! :cheers: :dance:
have you fitted them to the car yet? and do they work?! ;)
J@mes
e46psi.com ;-)
Jun 14, 2004
2,842
Copra said:
so....any updates?
does everyones car seem to be behaving themselves with these resistors?
what was the problem with the brake lights which were failing to illuminate?
my car has been fine for ages! :yes:
we only need these resistors to stop the 3rd brake light in the spoiler from glowing at night time when the sidelights/dipped beam is on...
the reason it glows is because the LED lights are far more efficient than a normal bulb and therefore the resistance is too low and power leaks up to the spoiler brake lights! :( (well thats my understanding!)
others got the CEL on their dash come on, but once you have the resistors fitted u can clear the CEL with vag com and then it shouldnt come back!
i never got a CEL, but i did get a fault register re the brakes, but it didnt bring the CEL up.
hope this helps!
james :)
aphix
239
Camberley, Surrey
I'm still having problems .. where-by the brake lights dont come on.. and if you pump the pedal they get well confused to the stage.. where you can sit with your foot on the brake.. 5 seconds late the brake lights come on...
Disconnect both resitors and its fine...
hopefully gonna sit down this week and find out whats going wrong. In all fairness i havent really had the time to do anything about them and check to make sure im not doing anything stupid.
Rob
