Melba Toast
___________
Mar 3, 2006
68
Newbridge - South Wales
Hi
Ive developed a nasty grinding noise on the front O/s of my Leon when I brake and it judders slightly which I can feel through the pedal. The noise/judder stays after I release pressure off the brake for a few seconds then its gone.
Any ideas?
I thought if it was the brakes a warning light would show up?
Also, theres rust mixed in with the brake dust on the alloy on the O/s.
If its not the brake pads, which you should check, it could be a stone or summat caught between the pads and the disc. If it is a stone and your not sure about removing the pads then some heavy braking should sort it out
I would say its the pads/discs to mate as mine was making the same noise from the rears and I changed pads & discs and this stoped it. When I removed the pld ones there was still a good 5-6mm left on the pads but there was still grooves/scratches on both the discs and pads.
Looks like the pads / discs then. I would have thought a Leon Fr would have had some sort of warning light? No warning light for the brakes but at least It lets me know when my washer bottle is low!
