H&R front camber adjusters
cr33p
diesel powah!
Sep 11, 2006
141
Slovenia
http://www.h-r.com/index.php?inhalt=produkt-f&sprache=en
Are these any good? My front tyres wear out on the outer edges a lot, even if they're pumped to 2.7bar. I guess I need to slightly adjust the camber up front.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
you will have +/- 2 degrees of camber adjustment on your existing bolts.
which is plenty to setup road car geometry
cr33p
diesel powah!
Sep 11, 2006
141
Slovenia
You mean I already can adjust the camber +-2 degrees, or I will have that option with these nuts from H&R?
cr33p
diesel powah!
Sep 11, 2006
141
Slovenia
"will".... future tense....Ok I get it... sorry, but English isn't my primary language :)
Thanks for the info!
Now i've got to measure the bracket width, so I can order the correct set!
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
you have 2 degrees plus and minus on your "existing bolts" - no need for H&R ones if this is enough for your plans..
What camber adjustment are you looking to achieve and why?
cr33p
diesel powah!
Sep 11, 2006
141
Slovenia
I live in the countryside - lots of twisty roads here. So my tyres usually wear out on the outher edge, and a lot! Even pumping the tyres higher than the factory spec is doesn't help. Last front tyres I wore out in 2 months, with the outer part completely worn on both front tyres, while the center part still had 3mm left.
I'll go to a garage to have the wheels aligned and ask them to make a slight negative camber at the front.
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
you can achieve this with your std bolts no problem.... no more than 1.5 degrees negative for a road car but make sure your tracking is reset and checked.
