Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
Anyone noticed that the heater fan speeds up when you select reverse??
Handy way of checking you ARE in reverse but it also prevents exhaust gasses entering the vehicle through the air bleed vents at the rear of the car......
Bloody cunning what??
I noticed, so if it is a hot day thanks to non existent global warming and you just can't cool the car enough, pull over drop into reverse and feel the benefits, hehe.
ED
Mk 5 Ibiza 1.6 CR TDI owner - anyone got advice on changing the main beam headlight bulb please? - I'm wanting to upgrade the bulbs and have done so with the dipped beam and indicator bulbs but the main beam bulb seems to be 'fixed in' and does not have the usual bulb retaining clip which when unclipped from the back of the bulb frees the same for removal? Any advice would be gratefully received please! Thanks in anticipation
Hello My name is Val, and I'm not a happy bunnie at the moment....(
Became the proud owner of a brand new Seat Ibiza 1.6 TDi Sport Coupe with many extras last September, and am having trouble with my 'Baby Blue'..... I have an engine noise that I absolutely INSIST it has had since I took possession of it, it makes this noise when I ask for more power from it, always when I press the accelerator pedal.... Took it back and Seat (Thompson&Thompson - Caldicot) said it was 'normal'...........
For those who have the convenience pack fitted but don't know how it works....
When parked up and ignition off (and key NOT removed from transmission yet) flash your lights once. After you have removed key AND opened the drivers door, the headlights will come back on for 30 seconds or so.
Pretty handy if you park facing your front door, rather annoying to the neighbours over the road if you dont![]()
