Sauniere
Hi,
I have a 02 Cupra and the heater just isn't working properly. I had noticed that on occasions cold air suddenly started blowing out of the wrong outlet for short periods of time but wondered if this was some way of regulating the interior temperature. Anyway after a while it became the norm that cold air blows out of where I don't want it, regardless of temp setting. It occasionally blows warm air from the right vent but not very often now. This has become quite urgent due to the time of year, I could demist using the air con setting but as the temp is now below 3 degrees it won't come on.
When I set the heater to demist the windscreen I can sometimes here a force 10 gale blowing behind the dashboard. If I open the dashboard vents freezing cold air gushes out at a pretty high force.
I've had this in to a Wincanton service centre (my wife works for Wincanton & their fleet cars are all VW) and they told me that it could be thermostat, heater matrix, flap motor, climate control unit. They stripped down the interior to check what it was and couldn't find out for some reason. The have decided to change the thermostat as it is relatively cheap. Any way it wasn't that. I have since had the bill for this work and it comes to £200without a fix about £12 of that being the thermostat, rest is labour!! The next step they say is to strip the dash out and replace the radiator which is a day of labour and around £50 for the radiator
It's doing my head in. I've had someone clean out the rad using a dishwasher tablet and then flushed it out. This seemed to work for about a day but it could have been a total coincidence.
Sorry for the long winded explanation but I just need help in diagnosing this problem otherwise it looks like I'll be out of pocket by £500 and still without a warm car.
Any help would be much appreciated
Cheers!
