andy_dea
427
north east
got a usb lead of ebay like many others, now the usb software off the ross tech website searches for a ross tec lead, which mine is not, any way to get it to read my usb lead?
or a diff version of vag com?
please help
cheers andy
you might need the usb to serial software (should have come with the usb lead)...
then keep trying different software versions, and keep going back in versions till one works....
Buy ****, and this is usually what happens, money saved or well spent you be the judge. I bought the Ross Tech usb cable and its been spot on from day one and it earned its cost within 2 months with myself and custardcupra using it. You get what ya pay for.
Hi Andy
I'm in a similar position to yourself Bought a usb lead off ebay fr my 2000 toledo tdi and I'm having trouble getting it to communicate!:confused:
How did you get on with yours mate?:help:
robertbadlad said:
hi there i had the same problem.
i have 303-1 and the cable didnt work.
diggy gave me a different driver and now all is working perfect!
i would try the same if i was you.
Any chance of posting link to the driver please!!!
also. try testing all the com ports on VAG COM, my doesn't match up to the correct port in device manager but it works fine!
thanks mork, those hints were spot on, cheers, being trying to sort thisfor ages now
thanks again
vag com
i also have same problem, iv tried downloading all the links hat have been posted and yet no luck, i have also tried com ports 1 - 4 and usb but no luck, does this need to be pluged into the car to find the usb device?
cheers
o bugger! then there is sumthin wrong! which download do i need from ross tech?
409.1 but which one?
TWIN-
MAX-
UNI-
ISO-
BI-
hi i need urgent help! i had bought a serial interface kkl. that worked fine with previous car (audi).
Now i bought a leon. and i replaced my laptop. The problem is that my laptop dosnt have a serial interface. i bought a usb > serial interface from maplins.
The problem i is when i check the engine controller, i get eror msg saying " baud rate error.
Any suggestion will appreciated
Usb to serial converters do not work well with some modules. For that reason, Ross-Tech does not support them as our FAQs state. You need to look at getting a genuine USB interface.
It this is related to your other post, this is the problem, not the Windows version.
