help needed mk1 leon pd150
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
HI all
no been on for a while :hole:
for a approx. a year now ive been living with intermittent central locking issues
the passenger door does not always open and you have to f**k about locking and unlocking before it eventually unlocks
and another issue is the drivers door does not recognise its open as the light doesn't come on and relocks within the 30 seconds or so
at first I thought im not spending over £130 odd to have my light come on when I open the car however I think the drivers door also activates pre glow plugs and fuel prime as I also have a starting issue which takes ages cranking over
however I have scanned with vagcom again and the only fault is the passenger door no mention of drivers
I will post the scan results up with fault code later
has anyone bought the ebay specials on door lock modules vary around the 20 quid mark any feedback on them
cheers
Andrew
sockpuppet
837
I think most of us are using the ebay specials. It sounds like your drivers door is a replacement lock and the 8 pin connector isn't pushed fully home or the clip has broken and the connector has slipped down. The door will lock and unlock but won't activate the lights and doesn't know when it's open and shut.
I had this on both my front doors, I spent an hour pulling all the butyl off the resealed panel on the drivers side, pushed the 8 pin connector fully home and super glued it in place and everthing works as it should. I need to do the passenger side as well one of these days.
This was the one I bought:
http://www.ebay.co.uk/itm/SEAT-LEON...LOCK-MECHANISM-1999-2006-8-PIN-/151362765504?
Andrewcupra TDI
Apr 30, 2008
3,282
thanks for the info , I have bought a pair of front modules been as they are cheap and by the time the door is stripped down saves hanging around before parts arrive etc if it turned out not to be just plugging them back in
at this point I can reseal the drivers leaky door again
im hoping this will also resolve my starting issues with the drivers door recognising its opening again - but I doubt it :(
bruceR
2,540
616
Monifieth, Dundee
I've just replaced my rear offside module with one from the 'Bay and it was an excellent fit and works perfectly - would recommend these (and I'm normally fussy about cheaply parts like these)
Andrewcupra TDI
Apr 30, 2008
3,282
great news just hope ive chosen a tidy seller lol
just ordered a load of other things too new hids new diesel hose pipes fuel filter and new valve
going to refit the std airbox and remove the carbonio
going to attempt to get this car back to running tidy
