Haven't fitted as yet, as time was running short.
I did check the "flash" situ while the test setup was hooked up, and all seemed ok.
Still unsure about the H1 HID's. Altho the flash works fine, i'm not sure about how long the bulbs will last with the intermitent use that main beam's get.
As for the connection fix I mentioned above, it works perfectly...the extra leads don't even need to be that long (as it's all inside the light box...all I'd say is make sure you tape up the connections to avoid any shorts.
