help needed with parts
teeth2k
908
sussex
i have just run vag com and i have two faults and need parts for my cordoba 2.0 16v 97 plate
engine coolant temp sensor
abs wheel speed sensor rear right
your help will be most helpfull
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
::temp sensor::
dash temp gauge reads off the single rear one at the back of the head
from memory the ecu runs off the 2pin one under the dizzy
iirc fan signal/ac run off the 4 pin one in the water pipe
::abs sensor::
check rear sensor/wires too might not need a new one
teeth2k
908
sussex
from mem the coolent temp sensor is located in the main engine block? thing is i changed this a while ago but didnot fix the problem tho i did read a while back that they can be faulty from new?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
been looking for a home to connect my water gauge up to recently hence knowing the rear one is the speedo gauge one and the engine spluttered like hell when i unplugged the twin white one so assumed that's the ecu one
etka is as clear as mud to be honest as to what's what though sorry especially when you add mfa/ac in the mix too
not unheard of to be faulty new though - what fault code you got ? and does it re-appear when cleared ?
ill check elsawin later see if i can nail it down
