HELP! Still not enough boost
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
If you haven't read my other post then just a quick update
Fitted my boost gauge and was getting 10psi
Tried another gauge and was getting same reading
So I asked on here and someone asked for my 3rd and 4th gear readings which are below these were done before fitting the N75 Valve:
3rd Gear
4th Gear
Then looking at the figures someone said it looks like N75 valve and so went out and spent £70 on a nice new one for it to make no difference.
Its not the MAF as a replaced that a few months back
There is no fault codes on vag-com apart from outside temp sensor which I doubt will make the boost low
I have the following mods:
Stage 1 remap
Jetex Filter
007P DV
Cat back exhaust
If anyone can help it would be appreciated i'm loosing my rag with this car now [:@] and i just wanna :cry:
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Could you get a log of 118?
Possible boost leak but then again the map doesnt request much at all so it could have been mapped pretty conservatively making it a mild map, if thats the case im sure will at p-torque could easily crank it up for you.
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
what gear to log 118. I emailed will who suggested n75 valve which i did and still nothing so waiting for a reply from him. Thanks for replying
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Always best to log in 4th gear if safe enough to do so.
Make sure the N75 is plumbed in the correct way around also.
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Anyone got a picture of N75 valve so i can check its right way, I just put it back on the way it came off i think
Dougy
Ibiza Cupra R
Dec 10, 2008
238
Yorkshire
Somebody has told me this could be the actuator and that it can be bypassed to check it
Is this safe enough to do aslong as I don't go mad on the pedal
