thecalstanley
72
Manchester, UK
Hi,
I've managed to get something in the switch for the windows so it only now clicks once instead of twice to put the window down without you having to keep hold of the button.
How hard is it to remove the switch and remove the tiny bit of plastic I've managed to get stuck in it.
Had a look online and it looks like you have to remove the whole door card which seems a bit excessive!
Any help would be much appreciated!
Thanks,
Callum
Thanks for this! Isn't a way to do it without removing the door trim. Suppose I'll leave it for now and hope the plastic moves out the switch area.
You could try a powerful vacuum cleaner with a thin nozzle or a can of Air blaster. Or see if you can hook it out with a thin paper clip.
