update: when i switched the ignition off and got the icon menu, i’ve opened the passenger door and a sub menu appeared display vehicle status. when i press it i see warning like door/ lid open. if i tick the icon which turn orange i cant enter the display vehicle status... its like keypad lock or something... not sure why, if i dont want to see the vehicle status then i just wont press it. so its still unclear what this icon does but at least it does something
There is another mib2 nag screen which is check safelock which you see. Might be a variation on that. You also have safelock as well. Page 102 of the manual attached. Interesting I see they also document the passenger door senser on the Leon 4 Kessy vehicles being turned off over a long duration without use. The 2016
Ateca does that. I know that's a function, first time I've seen that in a manual. On the same page below... why that sensor stops working after a bit and walk round to the drivers side is required.
Toss that out on safelock in case that icon may be something to do with that. The manual tells you the double press to turn the volume sensor off from the outside... it probably just means don't leave pets and kids in the car when you lock it else they can set the alarm. Leon 3 thread on that. Oh yes and they can't get out if you lock them in... Think that's the true meaning of the nag screen. Best not to lock humans in the car either way avoids them panicking. Pets something different.
Check Safe Lock - Check Owners Manual This message appears every time I turn the engine off. I've looked through the owners manual and can't find anything, does anyone else have it? Is there a way to get rid of it?
www.seatcupra.net
Throw this in just in case it's something to do with safelock warning but then perhaps you still get that nag screen ?. Might have a bearing if its not a reminder to take your phone with you
... sure that icon looks like the phone and cradle though.
