kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
www.wepaintanypart.co.uk
Results with air filter removed as my enclosed filter is said to be restrictive, it does sound alot better and you can hear the DV recirc, but according to the logs airflow is less :S There is also absolutely no timing pull. I've noticed actual boost is sometimes lower than requested? This is stage 2 1.8t.
Blocks 001, 031, 115 in 4th
Code:
Group A:	'001				Group B:	'031				Group C:	'115
	Idle speed	Coolant Temp	Oxygen Sensor	Adj for Basic		Voltage	Voltage	Bin. Bits	Bin. Bits		Engine Speed	Engine Load	Spec. Boost	Actual Boost
TIME	700-820 rpm	80-110 C	-0.2	1x111111	TIME					TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar
STAMP	 /min	°C	%		STAMP	 V	 V			STAMP	 /min	%	 mbar	 mbar
35.56	2360	90	0	1110101	34.76	0	1.085	        	        	35.16	2440	9.8	1000	1000
36.76	2280	89	0	1100101	35.96	0	1.085	        	        	36.36	2320	9	1000	1010
37.96	2320	89	0	1101001	37.16	0.035	1.085	        	        	37.56	2280	46.6	1000	980
39.36	2520	89	7.8	1101001	38.47	0.075	1.085	        	        	38.96	2440	99.2	2430	1400
40.57	2840	89	0	1100001	39.76	0.765	1.085	        	        	40.16	2720	124.8	2480	1760
41.76	3200	89	0	1100001	40.96	0.765	1.085	        	        	41.36	3040	148.9	2420	2090
42.96	3600	89	0	1100001	42.16	0.805	1.085	        	        	42.56	3480	175.9	2310	2400
44.47	4080	88	0	1100001	43.46	0.84	1.085	        	        	43.96	3920	176.7	2290	2350
45.67	4440	89	0	1100001	44.87	0.86	1.085	        	        	45.27	4320	173.7	2250	2260
46.85	4800	89	0	1100001	46.07	0.865	0.935	        	        	46.45	4680	171.4	2220	2150
48.07	5080	89	0	1100001	47.25	0.875	0.975	        	        	47.65	5000	165.4	2200	2030
49.36	4840	89	0	1110001	48.56	0.71	0.96	        	        	48.96	5000	19.5	1000	1120
Blocks 002 020 115 in 3rd gear
Code:
Group A:	'002				Group B:	'020				Group C:	'115
	Idle speed	Engine load	Inj. period	Air mass in		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		Engine Speed	Engine Load	Spec. Boost	Actual Boost
TIME	700-820 rpm	15-25%	2.0 - 4.0 ms	2.0-4.5 g/s	TIME					TIME	700-6800 RPM	15-150%	990-1800 mbar	<=1800 mbar
STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	%	 mbar	 mbar
0.8	2880	18	2.05	10.39	0.01	0	0	0	0	0.4	2880	16.5	1000	1000
2	3000	64.7	6.97	38.83	1.2	0	0	0	0	1.6	2920	45.1	1000	1010
3.2	3240	80.5	9.43	47.64	2.4	0	0	0	0	2.8	3120	78.2	1140	1280
4.38	3600	128.6	16.4	98.56	3.6	0	0	0	0	3.98	3440	88.7	1630	1270
5.58	4240	173.7	22.55	140	4.78	0	0	0	0	5.18	4000	175.9	2210	2310
6.78	4880	166.9	22.55	157.64	5.98	0	0	0	0	6.38	4680	172.2	2160	2150
8.09	5480	158.6	22.55	163.81	7.18	0	0	0	0	7.6	5280	160.9	2080	1980
9.4	6040	150.4	22.14	167.97	8.49	0	0	0	0	8.89	5840	151.1	1970	1820
10.6	5400	14.3	2.05	13.36	9.8	0	0	0	0	10.2	6080	121.8	1000	2120
11.79	4640	8.3	0	7.17	10.99	0	0	0	0	11.39	4720	9	1000	1050
13.08	4440	9	0	7.86	12.19	0	0	0	0	12.68	4520	9	1000	1030
14.38	4280	9.8	0	7.5	13.48	0	0	0	0	13.88	4320	9	1000	1030
is your filter been cleaned? how old is your maf? ive replaced my maf as i atugh it was the problem (old maf under a yr old) and the new maf only increased it by3-4gs....you may want check for boost leaks....
Didn't know until recently boost leaks can cause poor maf readings...
On my boost gauge where it used to quickly spike then drop instantly now it just goes to 19psi in a normal speed and drops slowly to 16...
im in the samboat as you as i cant get more than 150 g/s... had boost leak from the boost gauge vacum line, lower charge pipe kepst blowing off, the n75 wont boost past 1.3bar and drops so quickly to around 0.8....
now hav new n75J. 1.65bat to around 0.9/1.0 bar to 6k.....
stock ic pipes are crap
