help with these codes please
herb2578
now a cupra owner
Jul 14, 2007
145
west mids
its for my 2000 leon cupra
addess 01 : engine
5 faults found
17705 - pressure drop between turbo and throttle valve (check d.v.!)
p1297 - 35-00 -
17526 - oxygen (lamba) sensor heating; b1 s2: open circuit
p1118 - 35-00
17522 - oxygen (lamba) sensor; b1 s2: internal resistance too high
p1114 - 35--00
17545 - fuel trim: bank 1 (add) : system to rich
p1137 - 35-00
18010 - power supply terminal 30: voltage to low
p1602 - 35-10 - - intermittent
readiness: 0000 1001
address 15: airbags
1 fault found:
00532 - supply voltage b+
07-10 - signal to low - intermittent
address 36: seat mem. drvr
1 fault found:
01008 - note; emergency off switch is active!
the reason im asking for help is because i recently had a remap and forge 007 fitted and a 2.5" turbo back system where they cut the original cat out and rewelded it into the new sytem and where i had the diagnostic done has told me to go back to where i had it remapped and see what he says and then get back to them and im pretty sure he told me the lamba sensor that will need replacing is the 1 after the cat is this right or am i being messed about ???
all help appreciated thanks
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I wonder if they've fitted the probes the wrong way round.... but certainly one of them is broken (and it's the one that should be post cat)
herb2578
now a cupra owner
Jul 14, 2007
145
west mids
never would have even thought of that is thier a way of telling like a arrow showing the flow direction thanks
