Hi Andy,
How did you wire the guage up (wires for lights)?
Black to earth?
Twist yellow and orange together and tap into light switch?
Purple to permanent live?
ta,.
hi chris
to be honest i just held the wires on to a connection just to see the look.
weather permiting im hoping to wire the electrics in correctly tonight.
i think yellow is perm orange is dimmer and purple is background light
cheers
the halfords one is a boost/vacuum one is this still the one to use
I asked Halfords (via their web form) whether they could supply a standard boost gauge instead of a boost/vacuum gauge. See their answer in the Customer Q&A section here.
Click the tab to read questions and answers. I asked them again, but a little more specifically this time.
Bought these today.....
i intended to buy one but as they were overcharging me (the manager) the guy at the desk told me to take two lol
so if anyone needs one give me a shout
how much were these and where did you get them
im a little confused. what is this Buzz sound you are all on about?
do you get it if oyu get the EGR delete pipe taht has the boost pipe part on it?
Lee
Lee
the buzz sound is a common thing with boost gauges its to do with there not being a constant pressure going to the gauge (i think) and people have had it without the egr race pipe
any chance you can let me know where you got them connetors from as i need one myself unless you wanna sell ur spare one??
Ive been running a boost gauge on my fabia vrs for ages
used one of those tapered hostails off bearing boys
just drilled a 13mm hole in the plastic boost pipe on the left, applied some PFTE tape, screwed it in, then applied a thin bead of black sealant around the outside to make sure of no leaks.
I have swoosh gauges and even with a no-buzz t piece I get buzzing when giving it some.
rather annoying, but liveable
without the no-buzz, you would crash the car on purpose after an hour driving its THAT ANNOYING, it doesnt even buzz it rattles even when driving normally as through someone had a set of maracas sat next to you.
where does everyone stick the restrictor? i read that the closer it is to the gauge, the less chance of the shivers everyone gets on the diesel lumps!
(read it on a few USA forums)
You will have got a 3 way T piece with that boost gauge Andy. You need to look in the ends, you'll see a valve in one end of the t piece. Blank one of the other t piece ends off and attach the hose to the other. You'll have one from the intercooler going into the end with the valve, then the other running from the t-piece into the gauge.
