Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
basically to work out the offset of a wheel you split it in half (width wise) and then measure from the halfway line to the back face of the wheel that would meet the wheel hub. This number will be referred to as ET and the cupra's recommended ET for a 7x17 is ET35 to ET38. As a rule of thumb you can normally move +/-5 either way so if you car was recommended to run a ET38 you could fit a wheels that ranged from ET33 to ET43.
What confuses people is that as wheel diameter increases the width will generally also increase which will obviously increase the distance from the centre of the wheel to the back face of the hub.
Use this calculator, type in your current wheel stats and the stats of the new wheel you want, and it will tell you exactly how much clearance your new wheels will leave you with. Easy.
