vngtx
just wondered if anybody knew how long it would take to swap gti 8v engine and gearbox? replacing both at the same time. gonna have front end off out of the way and get an engine crane.
Like for like?
I could do it in 4hrs, probably including removing the front end. Probably a fair bit less if there was more than just one person doing it.
front end can be off in 20 mins tops since its tiestrapped on. just me unfortunatley.
doddle then - worst part of the whole job will be undoing the exhaust manifold nuts, and the driveshaft bolts.
All the rest is quick & easy. Just jack the car up as high as possible & remember to leave the power steering pump on the car, not connected to the engine.
when i put downpipe on i copper greased the threads all up.
well it took me 4 hours just to get my gearbox out! but then again never had experience before :)
I'm guna Say about 5 hours all in took me over 3 days 3hours but I was distracted lable all ur wires upon removal even if u position ao u no where it goes also get if self A spotter incase it falls on u or u get in trouble ( look at me I start an engine conversion and imbgivibg advice ;) haha)
While ur going that get a decat pipe clean ur engine an check everything so u don't put It in and find needs a new pump/ seal /badger
already decatted mike and already been told off by coppers ;) anybody know the best way to get gearbox oil off the engine bay?
i used wd40 and then lomng task of a clothe wipe ;)
talking about cleaning gearbox oil or ur :moon: ?
lol i also have a drill bit that has a wire brush nice bit wd40 and a cloth then wiring gets it all up why u spilling ur gbox oil any way and vince make sure u do it right pleaeeeeeee i dont want to read in a few months u been scammed or destroyed it
cos gearbox exploded a while ago and im only now getting around to swapping it.
im gonna attempt to get them out this afternoon. im excited to strip the old gearbox and see how bad it was :)
i think new engine is coming with loom attatched upto the ecu but dont know for sure. got a spare alternator and power steering pump with it and what im hoping is a working dizzy that isnt run by timing thats out.
ahh ok not to bad then just make sure vince as u never no ;)
