Unfortunately it is not well documented how to retrofit Cupra and Start/Stop Engine buttons from VZ steering wheel in Leon 3.Hi everyone, I'm Carlos, I have a 2019 Leon MK3 with VC, following the forum I got all the parts to have a heated steering wheel, with the ring to have start buttons and driving modes, also the steering wheel, the 5q1 adapter for the ring, my question is... Having these components, what additional wiring do I have to do, so that the start from the steering wheel and the driving modes work. Thank you very much in advance
There is no dedicated wire in airbag loom nor slip ring for Cupra button. It is integrated within CAN/LIN communication between slip ring and BCM/Gateway - don't know much details about that but it doesn't matter in your case - thus why you have to adjust gateway parametrisation.Tengo el anillo 5Q1953549G, estaba pensando en pasar un cable al botón de arranque de mi auto, y un cable al BCM donde están los modos de conducción... pero no se vería muy OEM.
Hi, the required 5q1 G slip ring for the VZ steering wheel with satellite buttons has a different pin layout than that of the standard steering wheel (on which this thread is mainly focused on in terms of wiring diagrams etc). The pin layout of your Aliexpress adapter is probably incorrect. You should compare your car's wiring with that of a Cupra VZ/VZ5. Then you can determine the correct pin layout for the adapter. Connecting without checking the pin layout can result in loss of steering wheel functionality. As far as I know, the airbag wires are also on different pins for the G slip ring, so I don't recommend messing with it without proper knowledge.View attachment 51420¿Está bien?
It should be possible. But you need to make sure that the right hardware/software versions are installed. Start stop satelite will not work due to the lack of kessy in prefacelift models. Also I haven't found a vz steering wheel with satelite buttons and without DSG paddles yet. I'm not sure if they exist, and if they exist they will be rare.Hey can someone help me. So i have a Seat Leon Cupra 290 from 2016 with manual transmission. I want to upgrade the steering wheel to the mk4 version. I have Acc, lane assistent etc. is it possible to include the heated steering wheel and the button to change drive modes? can someone give me the part numbers and which module i have to code with vcds. (i dont have keyless). Thanks for your help
According to my list there is no available steering wheel with "VZ buttons" and without DSG paddlesAlso I haven't found a vz steering wheel with satelite buttons and without DSG paddles yet. I'm not sure if they exist, and if they exist they will be rare.
