How to Upgrade Brembo to bigger Brake Discs.
Dyscontinued
1,142
Leeds
Stumbled upon this guide to fit larger discs to the Brembo setup
http://www.drivertuition.com/LeonCupraBrakes.htm
Takes them from standard 323mm up to 330mm.
Also I'm not sure (due to the unclear phrasing) but might be able to go to 345mm?
The new disc is also 28mm thick but is a larger diameter of 330mm. These are same rotors as used on EVO and Imprezza 6pot AP track upgrade. (A larger rotor could be used, up to about 345mm.)
karlw
AKA Shifty - Modded LCR
Jan 29, 2010
218
Ipswich, Suffolk
woudl be good if you are thinking of tracking the car alot.
I have those Bell and Rotars on my Evo and it definitely knew how to stop with them!
Nice find [B)]
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
I have 330mm 2-piece discs on mine. Badger 5 bells and powervane rotors. You need a 3mm caliper spacer to allow for the bigger discs - badger 5 supply this as part of the kit. ~£550 all in for rotors, bells, spacers, bolt kits.
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
This is what im running on my car
dont need any bigger brackets or spacers on the car just fit and forget. really good stoppers on the track aswell
CupraMVR
Oct 19, 2006
1,371
Crewe Cheshire
sitting down ??
£400 + vat but will last alot longer than normal discs.
dont suffer brake fade cause 2 piece discs wont get as hot
wayne lcr
bored of it now
Mar 5, 2009
4,548
doncaster
not bad is there any way you can convert the small poxey back disc to run a bigger disc? or do you have to upgrade the caliper as well?
DannyC87
Mar 4, 2008
3,459
yours 325mm John? or 330s?
Ronin225
4,652
22
Worcester
Will be considering 308 rears, but me and phillc will double order keep the price down (maybe awesome group buy??)
I have 330s on the front and think you probably could go bigger
